Google Analytics (Hidden)
Wednesday, October 26, 2011
The Best Posts of the Month, September 2011
Hi guys and gals, back again for yet another round of the Post of the Month elections! The Poll is published here, please feel free to give your votes at any time and acknowledge the effort the authors put in it...
Sorry this is kind of late, my vacation with Mickey and friends stood between me and my laptop, so this had to wait...
For everyone who doesn't have a clear remembrance of the original postings, here's a brief summary of them all:
Nr 1: Rotate Generic Model in Place by Alfred Medina.
This thread started with the question on how to rotate an in-place Generic Model from a horizontal to a vertical plane (in other words: rotate around the x-axis). Seemed like it couldn't be done because of the constraint to the workplane the geometry was created in. Alfredo provided an easy and effective solution: Group the geometry you wish to rotate after which this is possible.
Nr 2: Organize Schedules by Steve Stafford.
Long standing wishlisht item: the possibility to organise Schedules in the Project Browser. By default, Schedules are organised alfabetically, thus forcing people to either use unnecesary and/or confusing prefixes in their Schedule Names, or search for the proper Schedule in a bunch of unorganised Schedules...
Steve came up with a solution to this which uses the possibility to disconnect the visible name of the schedule from it's actual name by using Group Headers instead of the actual Schedule Name.
Nr 3. Reconstruction Phases & Rooms by mdradvies
The thread started with a question about the way Phases should be set up if you have a situation where you want to show Rooms from an Existing Phase in a next Phase (in this instance Phase Demolished). Mdradvies provided two possible solutions: one with the use of overlayed Views on Sheet (Room not actually being in the next Phase though) and one which deleted the Phase Demolished and used Phase Filters to set up the desired visual representation.
Nr 4. Link ACAD Notes at Correct Scale by Steve Stafford
The thread started with a question about importing standard drawing notes from autocad in Revit. The author had problems with scaling and sheet placement of the imported notes. Steve posted a thorough how-to for this, also adding some pointers and possible pitfalls.
The thread started with a question on how to rotate an In Place Generic Model over the x-axis (from Plan View to Elevation View). This issue was finally resolved in a few different ways (Pick New Host, Group and then rotate). In response to the whole discussion Mr Spot posted a generic solution to rotating a Non-Hosted Family which will work in probably any situation: make it workplane based and host it on a (named) Reference Plane. You can now rotate the Reference Plane and with that the entire family.
Nr 6. Reconcile Hosting by Jrobker
A post (and entire thread) worth reading for anyone who works with third-party MEP Consultants. The thread started with a question about an error occurring when an Architects model has new Ceilings. All ceiling based MEP objects will get unhosted. Most can be rehosted again, but some stay "Not Associated".
In response to this, and the following discussion, Jrobker posted a complete list of all the "do's and don'ts" in collaborating with MEP consultants.
Nr 7. 2d Symbols as Component by Alex Page
The thread started with the question on how to create (2D) furniture in Revit. Alex provided a step-by-step tutorial on how to do this using the proper family templates. He also added the tip to create the 2D furniture on a refplane with a parametric offset to the Reference Level. This way, in plan view, elements with different heights will correctly obscure each other, even while they are just 2D.
Nr 8. Association Work Plane by Alfredo Medina
The thread started out with a constraints issue in a Door Family. Using the <Family:Type> would break the link between the parameter and the nested families which needed to be swapped.
Alfredo posted the correct workflow to do this and make the type swappable by parameter without breaking the link.
Nr 9. Multi-category schedule by Gaby424
Alfredo Medina started up the thread, asking the forum about the general useage of Multi-Category Schedules. It turned into a lively discussion which focussed on how to deal with the seemingly random availability of standard Out of the Box parameters, such as Volume, in a Multi Category Schedule. For the Volume, Gaby424 gave an easy but effective solution: using Multi Category Material Takeoffs.
Nr. 10 Curtain Walls Not Joining by mdradvies
The thread started with a question about joining two Curtain Walls. How to get a Curtain Wall join 2 glass panels correctly without a vertical mullion (glass with a clear butt joint).
mdradvies responded with a way to use the vertical mullions to create a sealant between the two glass panels. Give the Mullion Profile the correct size and offset and use the ootb L-Corner Mullion as a template. It will joint the two panels together, much like common building practise for butt joints and still look good in Detail / Elevation / 3D.
So, we yet again have some beautiful contributions worth voting for. Please cast your votes here...
50 comments:
  1. Thanks for posting this useful content, Good to know about new things here, Let me share this, . LINUX training in pune
    ReplyDelete
  2. At first, the older generations found these youngsters "refreshing". Honest youthful concern for their fellow-men was viewed on the official webpage as a character-building exercise which, if practiced within proper limits, would prepare them for the situations they would face when they eventually graduated into the "real world", provided, of course, that they do not take their activities too seriously.
    ReplyDelete
  3. All the topics depicted here are well interesting and meaningful. The topic is presented in well arranged and professional manner. Thank you.
    company formation in Dubai
    ReplyDelete
  4. We are trying to http://123essay.org/cheapwritingservice-org-review/ write best resources on for improving innovative stories. Every point we are following to write best stories and essays. That's really much important to gather concepts and reviews.
    ReplyDelete
  5. feel regret I did not know this before I read your article, thank for sharing twitch
    ReplyDelete
  6. Read online Urdu Digests,Urdu Books,Novels,Magazines,Safarnama,Islamic Books,https://pakbooks.net/
    ReplyDelete
  7. May I consider your ideas you are offered to your post. They are really convincing and will certainly work. Thanks for the post.
    License Registration in Dubai
    ReplyDelete
  8. Thank you for this useful content, It’s a very useful content that helps me to complete my assignment at right time. I would like to write about my experience of assignment help Australia. I am an academic expert here who provides reference assignment including Accounting, Management, Finance, IT, Economics, Computer Science, Nursing, Marketing; all Academic subjects to University Students across Australia or even globe. We are a big online assignment help providers who help students to get HD grades according to assessment guidelines and instructions.
    Those who are searching for assignment help in Melbourne, Perth, Brisbane, Adelaide etc. They can get an Online Assignment Expert - the No.1 Assignment provider. Any student who is ready to buy an assignment at affordable price, they can visit our marked website & can enjoy the benefits of our amazing and informative services. You can avail of our convenient online assignment help and samples available on our website for free. You can also download it from our website. If you want to get more marks in your university assessment. We assign the best writer according to the subject for your academic problems and help in assignment writing services. Our Customer Care Executives are available 24*7 hours to assist you in the best possible manner. Phone calls and emails are the best methods used by assignment provider.
    ReplyDelete
  9. You are very good at that.
    คาสิโนออนไลน์ที่น่าเชื่อถือและมีความเป็นมืออาชีพที่สุดในตอนนี้
    โปรโมชั่นGclub ของทางทีมงานตอนนี้แจกฟรีโบนัส 50%
    เพียงแค่คุณสมัคร สล็อตออนไลน์ กับทางทีมงานของเราเพียงเท่านั้น
    ร่วมมาเป็นส่วนหนึ่งกับเว็บไซต์คาสิโนออนไลน์ของเราได้เลยค่ะ
    สมัครสล็อตออนไลน์ >>> Goldenslot
    สนใจร่วมสนุกกับ คาสิโนออนไลน์ คลิ๊กได้เลย
    มีทั้งคาสิโนออนไลน์ หวยออนไลน์ ฟุตบอลออนไลน์ สล็อตออนไลน์ และอื่นๆอีกมากมาย
    ReplyDelete
  10. Thank you for making me understand about how an assignment expert is able to solve the doubts of students by going through many writing formats of assignments such as essays, reports, thesis, articles and many more. Likewise, there exist one such company as My Assignment Services that provides top quality assignment help Philippines at affordable prices. We provide world class feature of on-time assignment delivery, plagiarism check, partial payment, unlimited revisions, etc. You can contact our team of highly professional and experienced experts engaged in their respective field. We provide assistance in many subjects with our economics assignment help, Engineering, Management, and many more. Avail our exclusive discounts on our assignment help Philippines by contacting our experts at My Assignment Services.
    ReplyDelete
  11. myassignmenthelp is the leading online assignment help service that have been successfully serving the students of australia from a couple of years now. our extraordinary writing experts cover a wide range of subjects and domains for the students.
    ReplyDelete
  12. Get started downloading and install Norton setup antivirus software. It is used to defend any user against different types of error, virus and malware attacks. Norton 360 is an updated version of norton setup. Norton 360 has many new features such as automatic backup, threat protection. you can download norton 360 from here Norton 360 Product Key.
    ReplyDelete
  13. if you are facing any issue in your security so you no need to worry about McAfee provide the best protection for any kind of cyber attack and harmful viruses like malware and spyware etc. for more details you can visit our website mcafee removal tool
    ReplyDelete
  14. Roblox are the safest and best tool to get Free Robux and this is the reliable source to the robux treasury, nonetheless you follow the instructions and get it.
    ReplyDelete
  15. Webroot antivirus, internet security, and identity protection. Webroot SecureAnywhere® Mobile Free keeps you secure when browsing, shopping and banking.
    www.webroot.com/secure | webroot.com/secure |
    Install Webroot With Key Code
    ReplyDelete
  16. Dragon NaturallySpeaking software is a speech recognition program that allows the user to speak into a microphone on a computer with the software translating
    dragon naturally speaking | dragon naturallyspeaking
    ReplyDelete
  17. This info very good its really very very informative great stuff post i appreciate your work..
    norton.com/setup
    norton.com/setup
    ReplyDelete
  18. canon printer setup into your pc, your system does not need to install the driver on it. Canon printer that can be downloaded via page is the best wireless printer that you can connect to your device and print data smoothly. canon.com/ijsetup
    CD is not the well-suited technique to use canon.comijsetup setup installation for longer.
    ReplyDelete
  19. eset internet security can be installed quickly on each device if the user follows the correct procedure. You can follow the instructions below to install the setup on your devices such as Windows PC, Mac, or mobile device. www.eset.com/ca/download Best IT security solutions for your home and business devices.
    ReplyDelete
  20. Updates to the TomTom software and GPS maps are periodically made available to fix bugs and update road changes.
    tomtom.com/getstarted | tomtom get started | www.tomtom.com/getstarted | tomtom update
    ReplyDelete
  21. we are the best manual for the free robux and this is the only working existed way to roblox free robux
    ReplyDelete
  22. Dragon NaturallySpeaking 13 Home speech recognition software lets you - quickly and accurately - using your voice.
    ReplyDelete
  23. McaFee security offers simple and effective virus protection to help UA students, across connected devices.
    www.mcafee.com/activate
    ReplyDelete
  24. if you are using McAfee activate and looking for product key then you can visit our website where you will get the full information related to it. if you are facing any kind of error while using mcafee.com/activate then you can visit our website and share your problem with our technical assistant. and if you not installed any antivirus in your system then install it now. it provides maximum protection to your data from thread and viruses.
    ReplyDelete
  25. Dragon NaturallySpeaking remains the benchmark for Windows-based speech-to-text technology.
    ReplyDelete
  26. norton product key is easily available on any norton affiliate store or you can visit its official website to buy it.
    ReplyDelete
  27. Dragon Naturally Speaking Professional specifically for the legal industry, Nuance Dragon Legal Individual speech recognition software
    dragon naturally speaking | dragon naturallyspeaking | nuance dragon | nuance dragon naturallyspeaking | naturally speaking
    ReplyDelete
  28. Download antivirus and internet security products. Complete internet security with our award-winning security software.
    www.avg.com/activate | AVG Download | Install AVG with license number
    ReplyDelete
  29. Bitdefender Central - Bitdefender is a popular name within the cybersecurity market. Bitdefender also gives a variety of safety programs for home and enterprise use. With Bitdefender, you may access a variety of safety packages and offerings in a single region that also gives a couple of applications, including: B. Comprehensive tool safety, Mac safety, PC protection, Android protection for non-public use. Plus endpoint protection, advanced threat protection, information middle safety for enterprise use. As you may see, there are some of offerings that Bitdefender offers and sometimes it is able to be tough to manage all of those services at the same time. During this period, a user can use the Bitdefender login service.
    www.bitdefender.com/central
    how to download bitdefender already paid for
    ReplyDelete
  30. If you're looking for first-class results from the Webroot Antivirus program, at that point you could provoke and introduce this on line security with help from our specialists. Specialized help is available on-line that you can get entry to by basically dialing toll free wide variety on every occasion of the day or week. We will be cheerful to help you either through remote get entry to or telephonic path to guarantee smooth potential of our antivirus program. You can likewise Install Webroot with Product Key via downloading antivirus documents for your device.
    www.webroot.com/safe
    ReplyDelete
  31. AVG is one of the most trusted brands in the cyber security industry. It has offered strong security for several years. AVG merchandise to be had for the house as well as the use of a commercial enterprise. They can be used on multiple devices and systems running. What makes AVG stand out from other security suites is that it is a mile freemium. This way you can use it for free. To get the advanced features, you can purchase a subscription her.
    www.avg.com/activation
    www.avg.com/retail
    ReplyDelete
  32. Adorable!! Thanks for sharing these!
    SoLive For PC
    ReplyDelete
  33. Assignment help Australia offers affordable and reliable assignment help to students across Australia. All the specialised services can be availed in any simple or complex task of any subject or course at an affordable price thereby meeting the expectations of students looking for quality assignment help within some budgetary constraints. Convince yourself only after looking at the list of our free samples talking of our quality and expertise.
    ReplyDelete
  34. Thank you for sharing this type of article with this site. So i got many valuable information within this.
    Visit: malwarebytes downloads for already purchased
    ReplyDelete
  35. Thank you so much for posting like this. I enjoyed much more here. So please keep update like this.
    Visit: www.avg.com/retail
    ReplyDelete
  36. Thank you for this page. Thats all I can say. Apart from this i would suggest you to invest in properties like.
    Visit: how to download bitdefender already paid for
    ReplyDelete
  37. Very good post. it is very interesting and informative post. Thank you.
    Visit: webroot.com/safe
    ReplyDelete
  38. The students who are often in need for assistance in their assignment work are often led towards a trap by these so called online assignment help websites.
    ReplyDelete
  39. Our in-house writing experts upload accurate law assignment samples every day. We have PhD- qualified experts, industry practitioners, and experienced academic writers who draft the assignment sample for university students.
    ReplyDelete
  40. Everyone can buy all types of Gaming products in Chennai area from the below-mentioned links. Here you may find all gaming products at affordable prices. For more information, visit Game Shopee
    PlayStation 5
    Game Console
    Video Game Console
    Gaming Accessories
    ReplyDelete
  41. Very good post. it is very interesting and informative post. Thank you.
    Visit: WWW.WEBROOT.COM/SAFE
    ReplyDelete
  42. Nice Post. Thanks for sharing. This blog post is very important & effective.
    Visit: www.trendmicro.com.au/downloadme
    ReplyDelete
  43. business setup in UAE is a dream of many entrepreneurs so with help of business setup provider making your dream of setting up a business in the UAE a reality. When you are planning to setup a business in Dubai, every plan and decision should be made at the right time, and the expertise and experience are required. Business setup consultants in Dubai help you to setup a business easily.
    Quick Links :
    VAT services Dubai
    business consultancy services in dubai
    Business Formation In Dubai
    office for rent in Dubai
    ReplyDelete
  44. This comment has been removed by the author.
    ReplyDelete
